4.10 just dont work .....kid need HELP!!
Old Jun 10, 2006 | 08:49 PM
User56898's Avatar
I have a 67 camaro with a 333 smallblock and a TH350 trans. The rear is a GM 10 bolt. Currently i have 4.10 gears installed. This is simply not working for me. In 3rd the engine is at 4500 RPM at 55mph. I watch my gass gauge just drop lol
I have to shift into 2 at around 10-15mph
what gears should i try. 3.23 3.55. 3.40
Plz help!
thxs
Not drag car, street use, hardly ever need to go on major highways. Most the time i am at 50-55mph
Old Jun 10, 2006 | 09:12 PM
89385formula's Avatar
Re: 4.10 just dont work .....kid need HELP!!
I think there is something else wrong with your setup. Perhaps your tranny is slipping, or your converter is too large/loose. With a guess of a 26" tire since you didnt specify, with the slippage of a non lockup converter you still shouldn't be but a hair over 3K rpm's @ 55MPH. I would start trouble shooting.
Old Jun 10, 2006 | 09:19 PM
User56898's Avatar
2800 RPM stall
17 wheels 245/45/17 tires (yes small)
what could be wrong. trans not slipping. Also have B&M shift kit.
Old Jun 10, 2006 | 09:20 PM
User56898's Avatar
opps not 4500 it was 3500 my mistake
Old Jun 10, 2006 | 09:26 PM
Theres only so much you can do. 3500 isnt too bad, considering a smaller tire and what looks to be a fairly loose converter. A taller tire would help, although may not fit as far as looks go, or i would be looking for a better gear...3.55's or 3.73's would help drop the RPM's pretty well.
Old Jun 10, 2006 | 09:33 PM
User56898's Avatar
i am def changing the gears but idk what to!
should i go 3.20's 3.50's or 3.70's
Old Jun 10, 2006 | 09:34 PM
tell me what you can live with for RPM at around 60, and if you plan on a different tire size.. and i will try to help.
Old Jun 10, 2006 | 09:38 PM
User56898's Avatar
2500-3000 max
tire are to stay same
thx alot BTW
mostly want to change b/c i have to shift outa 1st at 5-10 mph. that seems way off to me.
Old Jun 10, 2006 | 09:42 PM
Depending on exact gear choices anything in the 3.4-3.5 area will work fine for your RPM requirements. Hope that helps.
Old Jun 10, 2006 | 09:48 PM
User56898's Avatar
okay will order ASAP
any brand better than others.
looking at richmond
Old Jun 10, 2006 | 09:50 PM
Richmonds are said to be louder...but stronger then others. I don't necessarily believe that to be true. Proper setup will be the key to any gear lasting long and being quiet. Good luck.
Kyle
Old Jun 10, 2006 | 09:52 PM
User56898's Avatar
I am not going to install them....buddy owes me for putting caddy lights in his S-10 lol
dotn care about sound, exhaust covers all! lol
I have richmond 4:10 in it now.
Old Jun 11, 2006 | 10:02 AM
Dennis93TA's Avatar
I have a '67 camaro with a 4speed muncie(4th is a 1:1 just like the auto) and i cruise 60mph at 3200rpm and i have 4.11 gears also. I love em. I went from a 3.08 to the 4.11 and i'm happy. maybe think about and overdrive unit for your auto.
Old Jun 11, 2006 | 11:06 AM
User56898's Avatar
how much is an overdrive unit for my trans. Is it worth it. I am on a budget....
Old Jun 11, 2006 | 11:13 AM
bmax's Avatar
Talking Re: 4.10 just dont work .....kid need HELP!!
check these calculators for the info you are looking for.
Brad
http://www.thedirtforum.com/rpmcalc.htm
http://www.5speeds.com/rpm.htm
