Doing more work on the turbo kit...
Old Jun 8, 2006 | 08:56 PM
RealQuick's Avatar
Started the DP. I was going to have it exit on the pass. side originally, then moved it to the dr. side, thats why the dp looks like it does. Cast manny's...T67...2.5 crossover pipes...3" DP.
Old Jun 9, 2006 | 03:22 AM
LT1-TA's Avatar
Re: Doing more work on the turbo kit...
so if we figure that i have the turbo sitting the opposite as you do... and have the DP going where your air filter is... then this design would work even better and be cleaner? because then you would not have to have the DP run under where you did it.
Old Jun 9, 2006 | 08:03 AM
RealQuick's Avatar
Dont know if it would necessarily perform better, but it would be much cleaner and easier to fab!
Old Jun 9, 2006 | 08:51 AM
HungryT/A's Avatar
RealQuick, this is some very nice work, keep us updated!
Old Jun 9, 2006 | 09:07 AM
RealQuick's Avatar
Thanks.
Old Jun 9, 2006 | 11:43 AM
LT1-TA's Avatar
it tis good work... so you should support him and buy it, put down some amzing power... and let him continue making turbo kits
Should work well to a certain power level, then i believe that DP would become a HP restriction. It tlooks well and I love how you jump in and just get **** done. But then again having something sitting there for mach-up helps a lot.. lol
Old Jun 9, 2006 | 12:19 PM
RealQuick's Avatar
Yeah, the DP will become more restrictive once you start putting some serious air thru there. If it were a smoother transition where it 90's up and goes over he k-member, it would be better. You'l be in great shape when you do yours since you'll have the turbine outlet facing the right way.
Mocking up outside the car is much easier
Old Jun 9, 2006 | 05:49 PM
LT1-TA's Avatar
You think bryan will be able to throw a decent mailorder tune out? I mean i dont even care if it is tuned pretty rich to be safe... because it still will be a new car with 6psi...
Old Jun 10, 2006 | 08:56 AM
RealQuick's Avatar
I think so. I would load the tune and check the part throttle and see how it reacts. Then hit the dyno for some WOT runs (and check A/F)....
Old Jun 10, 2006 | 11:35 AM
97WS6Pilot's Avatar
Nice work.
Old Jun 10, 2006 | 07:55 PM
Jermsmonte's Avatar
Are thoses just factory Camaro exaust manifolds?? if not what are they from?
Old Jun 10, 2006 | 10:23 PM
RealQuick's Avatar
Yeah, 1995 manifolds.
Old Jun 10, 2006 | 11:29 PM
LT1-TA's Avatar
lol.. you could jsut sell the hot side minus the manifolds and they could use their own.. lol that would be a good affordable way to do it for someone else
Old Jun 11, 2006 | 08:13 AM
RealQuick's Avatar
Driver's side would be fine, but on the pass. side the flange runs into the motor mount and needs to be cutoff...
Old Jun 11, 2006 | 04:58 PM
akafred's Avatar
looks good except for that one pipe? why is it all hacked like that? couldnt you use a smooth bend?
