Pulling engine
Old Jun 8, 2006 | 04:23 AM
Wildwill2855's Avatar
Pulling engine
Going to pull a friends engine, he has a m6. My thought is, i also searched, would be it better to pull the engine with the transmission connected or unbolt the 6speed and just pull the block. Also how hard to unbolt the 6speed, .... clutch?, ive done tq converters but never worked on a manual. Any tips would be cool. thanks
Old Jun 8, 2006 | 06:44 AM
teke184's Avatar
Re: Pulling engine
i say take it all out as one. remvoe it through the bottom. the trans is pretty easy to remove. something like 10 bolts around the bellhousing. i did it with the driveway when i replaced my clutch. couple of the top bolts require a 2ft of extensions to reach easily.
Old Jun 8, 2006 | 11:33 AM
Re: Pulling engine
you said pull it from the bottom? then pull it as one? whats that mean?
Old Jun 8, 2006 | 11:55 AM
Plague's Avatar
Re: Pulling engine
He means don't pull the engine out the top. Leave the engine on the front wheels and raise the body up. Also, 8 bolts connect the bellhousing to the block. 8 bolts connect the tranny to the bellhousing.
Old Jun 8, 2006 | 09:41 PM
GhostZ28's Avatar
Re: Pulling engine
In short: Pull the tranny. Then, drop the engine from underneath the body. I think I saw a full guide for the proceedure once if anyone has the link?
Old Jun 8, 2006 | 09:46 PM
Re: Pulling engine
thats not going to work lol, weve got it all tore down and unbolted, just got to get the picker tomorrow. i just dont know how to disconnect the transmission from the engine. any guides? thanks
Old Jun 8, 2006 | 09:53 PM
v-8's Avatar
v-8
Re: Pulling engine
Just unbolt the bellhousing and slid the motor forward, ther isnt any connection between the two, unlike the auto which has 3 bolts. hope that helps...
Old Jun 9, 2006 | 01:54 AM
GhostZ28's Avatar
Re: Pulling engine
really, just undo the 8 bolts that bolt the bellhousing to the engine. done. of course, undo your shifter and **** as well...
Old Jun 9, 2006 | 09:18 AM
SSpdDmon's Avatar
Re: Pulling engine
When we did mine, I think we got the two upper bolts on the tranny by going through the hole in the floor for the shifter with some extensions. With the shifter out of the way, you should try that. Might make it a little easier.
Old Jun 10, 2006 | 12:01 AM
Re: Pulling engine
someone said unbolt the 15mm bolts well thats the transmission from the bellhousing correct? so am i going to unbolt the transmission from the bellhousing, or the bellhousing from the block itself, i talked to a guy who does transmissions and he said for that car to unbolt it from the block. hope im explaining myself so it makes since.
Old Jun 10, 2006 | 01:01 AM
GhostZ28's Avatar
Re: Pulling engine
leave the tranny on the bell housing, and undo the bellhousing from the motor. Then pull the transmission and bellhousing out as one.
Old Jun 10, 2006 | 07:20 AM
AL SS590 M6's Avatar
Moderator
Re: Pulling engine
It's actually way easier to pull the trans off of the bellhousing then pulling the housing off the motor is cake. I've done it both ways.
Old Jun 10, 2006 | 11:30 AM
GhostZ28's Avatar
Re: Pulling engine
Eh, Thats just how i did it with my last clutch. I didnt wanna mess with unbolting alot of stuff jsut to keep it simple, but if its easier, i say listen to Al.
Old Jun 10, 2006 | 07:01 PM
Re: Pulling engine
so i took on i think it was 7 bolts from the bellhousing to the block, pretty sure ive got them all 1/2 they were. Now when it comes time to lift the engine out, ive not seen the inside of a t56, will they just seperate/slide apart? Or will i have to remove the clutch and clutch fork ect? if so what do i do to get access to them.
Old Jun 11, 2006 | 12:17 AM
SSpdDmon's Avatar
Re: Pulling engine
You want to remove the tranny before the motor if you're pulling it from the top (much easier to pull from the bottom, but hey...). Once the bolts are out, the trans should pull right off the back of the motor. Just be careful not to damage the input shaft. You should support it with a jack or something as they weigh more than 100lbs. It might need a little persuading too if it's been attached to the motor for a while. As for the clutch, it's bolted to the flywheel, which is bolted to the crank. It's not going anywhere. There's no clutch fork on an LS1. They're hydraulic, so you'll have to disconnect the hydraulic lines on the driver's side of the trans that go to the slave cylinder (pushes on the diaphram to engage/disengage the clutch). Hope this helps some. You might also look into getting a manual at an Autozone type place if you haven't already. They're good for torque specs and general instructions on procedures like this.
