Replaced broken tranny mount with poly one
Old Jun 6, 2006 | 11:24 PM
user 647483's Avatar
Uhm,
I think the old was needed replacing.
What do you guys think?
Old Jun 6, 2006 | 11:41 PM
1FstFormulaV8's Avatar
Re: Replaced broken tranny mount with poly one
I've broke so many of those I actually made a jig for the tranny and floor jack.
Old Jun 6, 2006 | 11:45 PM
I did too, I call it a 2x8
Old Jun 7, 2006 | 02:59 AM
1racerdude's Avatar
Poly will vibrate it's *** off and yours too.
Old Jun 7, 2006 | 06:12 AM
Jeff95TA's Avatar
That's what mine did. Seems to vary from car to car (or maybe some people are just more tolerant of the vibration).
Old Jun 7, 2006 | 06:29 AM
GetaZforgetGT's Avatar
Did you have poly engine mounts and poly trans or just a poly trans mount?
I've heard others say that it vibrated alot until they went poly in both (all three mounts, obviously) locations.
Old Jun 7, 2006 | 06:56 AM
Vibration is no problem at all.
I've had these on at least two Fbodies without issue.
Old Jun 7, 2006 | 07:07 AM
mccullar_racing's Avatar
Now whats a muscle car without some good vibrations?
Old Jun 7, 2006 | 11:02 AM
stik6shift93's Avatar
helps if you run an aluminum driveshaft, with the steel one it can be hit and miss depending on how bad the balence is off.
Old Jun 7, 2006 | 05:59 PM
eagleknight97's Avatar
Also depends on the company that makes it, and if its ES, then if you use the spacer plate, it will vibrate much more.
Old Jun 7, 2006 | 09:24 PM
justcallmebo's Avatar
Used the spacer plate on '97 A4 Z - vibrates very bad with poly mount. Thinking of going back to rubber..............
Old Jun 7, 2006 | 10:18 PM
xpndbl3's Avatar
those break sooo easily with just the slightest bit of power put to them, poly is the only way to go.
Old Jun 8, 2006 | 12:47 AM
Do NOT use the spacer plate, i had it in there for a year because I thought it was supposed to be in there and when i finally found out it wasnt, i took it out and boom...WAYYYY better. Compared to before, car felt like a luxury car when it idled.
Old Jun 8, 2006 | 02:14 AM
1racerdude's Avatar
A smooth driving car!!!!!!
Old Jun 8, 2006 | 06:29 PM
MeanGreen97Z's Avatar
That old Mark Wahlberg song popped in my head.... its just some good vibrations, come on come on come on .... feel it feel it! feel the vibrations!
