did I miss anything?
Old Jun 4, 2006 | 01:40 PM
GhostZ28's Avatar
So as soon as I gather all my parts I'm going to start my H/C install. I need you guys to check over anything that I might have missed.
All this is on my list of parts or I have already bought:
Patriot gold kit w/ dual springs (speedinc) ".650: $250
Futral F13 112: $400
LS2 chain: $46
Head gaskets: ?brand/price?
Hardened rods comp. : $120
Valves: ?brand/Size?/price (was thinking manley 2.02/1.57)
thats all i can think of at the moment
Old Jun 4, 2006 | 08:34 PM
Greed4Speed's Avatar
Re: did I miss anything?
The rest of the gaskets, head bolts, and balancer pulley bolt.
Old Jun 4, 2006 | 09:31 PM
GhostZ28's Avatar
alright I guess I'm good to go. Should I go with ARP for all my bolts? What about pushrods, if I deck my heads .020, will I have rod legnth problems or should the right head gaskets fix that?
Old Jun 5, 2006 | 07:56 AM
AL SS590 M6's Avatar
Moderator
What heads are you putting these parts on??
Old Jun 5, 2006 | 01:50 PM
GhostZ28's Avatar
243's. I'm porting them as we speak.. So far i have one head almost done, and I'm gonna take them to get flow benched to make sure I'd doing good. If all else fails...ebay.
Old Jun 5, 2006 | 03:34 PM
SSpdDmon's Avatar
The difference in the base circle of the stock/aftermarket cam and how much you deck the heads by will be a decent measure of where your pushrod length needs to be. The best thing to do would be to get a pushrod length checker for $20 from Speed, Inc. and measure the right length for lifter pre-load. Then, there's no guessing.
FYI - http://www.ls1tech.com/forums/showth...ht=preload+F13
Looks like you should invest in 7.425 hardened pushrods with the heads shaved .020.
Old Jun 5, 2006 | 04:12 PM
GhostZ28's Avatar
thanks for that!
Old Jun 6, 2006 | 07:15 AM
Moderator
Well then you have to put stock sized valves back in unless you're going to take the heads to a machine shop and have the stock 2.00/1.55 valve seats cut out and new 2.02/1.57 valve seats installed and the complete valve grind job done. And then you'd have to re-port that area to match the new valve sizes.
Old Jun 6, 2006 | 10:36 AM
GhostZ28's Avatar
thats the plan. I havent touched the seat area yet, just the access material around the guides and I did some smoothing around elsewhere.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
