3.42 or3.73 ???
3.42 or3.73 ???
I would like to change the rear gears in my Z and am considering 3.42's or 3.73's. Your thoughts, opinions, and advise would be greatly appreciated. If possible let me also know your performance experience. I have the stock 3.23's with an automatic.
Re: 3.42 or3.73 ???
On my 94 Z28, my first upgrade was to 3.73s. They were indeed fun as hell, but the streetability was pretty low. With gas prices the way they are today, ew.
I later dropped down to a 3.42 and was VERY happy. Perfect middle ground. I then added a 3200 Vigilante stall and WOOOO. The torque was just sick. I was cutting 2.0 60 foots at the track on STREET tires.
I highly recommend a combo of 3000-3200 stall with 3.42s. Worked great with my setup. I also had a nitrous kit, which I never go to put on, but it would have made for the perfect powerband on that setup.
Re: 3.42 or3.73 ???
My '94 is in the process of getting 3.73's put on as we speak......everyone I've talked to about it has told me that 3.73's were the best way to go for me, especially since I'm starting out with stock 2.73's.
I've been researching and asking around about this for a few months leading up to now, and the only bad thing people were telling me is the whole gas mileage thing.....otherwise, I have been told that 3.73's would be sick for my car. I, too, was initially going to go with 3.42's.
Re: 3.42 or3.73 ???
Originally Posted by Taintedz28
yall 2 be very careful with 3.73. that 10 bolt will take a **** on yall the first time you get any traction with those gear. i busted mine with the stock 2.73 and had brnd new bearings and gears in it
I've never heard anyone breaking it that easily with 3.73's. If you're hard on anything it'll break.
Re: 3.42 or3.73 ???
i break torqued it to 2k for a whole 4 seconds toh eat up my tires for another good high speed run and dint make it 40 feet before i alyhed out 500 feet of driveshaft, yolk, pinion gears, bearings, and axle casing
Either that, or you made a habit of brake torqueing and burning out.....
Re: 3.42 or3.73 ???
lol. you cant honestly tell me you dont plan on abusing it a few times yourself though
Re: 3.42 or3.73 ???
A4 had either 2.73's or 3.23's. if you cant slect 1st gear on your console, as in, you have no 1 gear thing there you have 2.73's. M6 cars had either 3.32's or the optional 3.42's
Re: 3.42 or3.73 ???
Re: 3.42 or3.73 ???
Originally Posted by 2000GTP
3.32 gears?? I have only known M6 cars to have 3.42s
