Need help with my 89' iroc 350 tpi
Old May 30, 2006 | 05:37 PM
89'chevyIroc's Avatar
Exclamation Need help with my 89' iroc 350 tpi
i need some help with my 89' iroc 350 tpi. the problem is i turn the key and get nothing. i've put a new battery,starter and all the cables for that. Before i put a new head unit in and it hasn't started now. but before that it was running but it was starting. so i really don't what is going on so plese help.
Old May 30, 2006 | 07:52 PM
Black305RS's Avatar
Re: Need help with my 89' iroc 350 tpi
make sure you connected all the wqires to the starter sylinoid i believe there are 2-3 big ones and 1 little one.
Old May 30, 2006 | 11:07 PM
89Vert's Avatar
are you getting signal power to the starter solenoid?
jump power the the starter solenoid form the big post(a screw driver works well for this)
if it turns over good, you got a control issue,
VATS wire breaking at the ignition swich is a common cause to this problem
G-BODYT56
Jan 14, 2022 11:14 PM
HAWG
Sep 25, 2015 11:41 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
