Cooling fans..
Old May 30, 2006 | 08:50 AM
fastchevy's Avatar
Cooling fans..
Well, I've been working on my A/C all weekend and it's working. I replaced the compressor, drier, high pressure line (cracked), and all O rings.
After getting the A/C working and noticed it's not cooling as much as it should, I noticed that only 1 fan was coming on and it's the #2 fan. I realize that someone along the way has jumped a terminal on the #2 fan relay (to a ground) to get to work. If I remove the ground it stops. The #1 fan apparently has never worked since I've had it (but the temps were fine). When I jump (the #5 terminal I believe) on the #1 fan relay connection my fan kicks on.
Would anyone know where to look as to why that circuit is open and not grounded? Right now I'm jumping them and they are both on while the motor is running.
I traced the wiring from the fans and it hasn't been altered, they go directly up and into the relay box/fuse box. The fan fuse is fine and doesn't blow.
TIA
Old May 30, 2006 | 08:07 PM
fastchevy's Avatar
Re: Cooling fans..
bump
Old May 30, 2006 | 10:15 PM
Re: Cooling fans..
I would compare what you got to the schematic on my Tech Page. Use the appropriate one for the 2 or 3 relay system (1994s could have had either).
Old May 31, 2006 | 08:26 AM
fastchevy's Avatar
Re: Cooling fans..
Thanks...that will get me started.
Old May 31, 2006 | 08:51 AM
CCRJon's Avatar
Re: Cooling fans..
Just make sure to check the relays in the fuse box in the engine bay. I had one bad one on my low speed fan and it never came on.
It might be a good idea to just go to autozone and buy 2 or 3 (depending on your system) relays. They run about 6-8 dollars a piece. Unless you have a manual fan switch and can turn them on and off at will to know which one is bad.
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
damnyankee36
Sep 9, 2015 07:06 PM
