lumpy idle warm? smooth idle cold?!
Old May 29, 2006 | 02:12 PM
niteriyder's Avatar
My 99 z28 A4 (50k miles) idles at 600rpms when cold and purrs like a kitty, but once its warm and the idle drops down to 500rpm-490rpm it feels lumpy, enough to cause a moderate vibration as well.
Could the spark plugs be going out?
Old May 29, 2006 | 05:31 PM
Greed4Speed's Avatar
Re: lumpy idle warm? smooth idle cold?!
Idle is too low. Should be around 700-750 for RPM for a M6 higher for an A4 out of gear. Thats why it is smoother when cold because it's idling higher.
Old May 30, 2006 | 07:41 AM
AL SS590 M6's Avatar
Moderator
IAC is probably acting up or passages are dirty.
Old Jun 1, 2006 | 01:03 AM
JDBlaze85's Avatar
when your engine warms up to operating temp, the fuel system enters closed loop and the 02's take over your injection. check your 02's and LT trims.
Old Jun 2, 2006 | 02:11 AM
niteriyder's Avatar
iac? LT trim?
how can i check for a bad O2 sensor?
appreciate the response guys
Old Jun 2, 2006 | 05:30 AM
Moderator
Originally Posted by niteriyder
iac? LT trim?
Idle Air Control.............on the throttle body
Long Term fuel trim..........a function of the PCM
Hook up a scan tool and watch them cycle.
markzzzz
May 8, 2015 09:21 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
94Form
Feb 10, 2015 11:23 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
