Broken SIR coil.. is there anything to test?
Old May 28, 2006 | 04:52 PM
Javier97Z28's Avatar
Moderator
Is there any way to check an SIR coil to confirm that it's bad?
During the engine swap I had no idea about the "don't spin the steering wheel when shaft is disconnected deal" (i haven't had my steering shaft cover on in years), and I guess myself or someone spun the steering wheel a few too many times.. oops.
What actually breaks? Can I test something to see what it is?
Old May 29, 2006 | 12:39 PM
OBE1 95Z28's Avatar
Re: Broken SIR coil.. is there anything to test?
The coil contains a wiring harness that only has enough slack to cover the normal rotation of the steering wheel. Most likely you could perform a continuity test of the harness; Shoebox may have an electrical diagram on his site.
KYWes
Jun 14, 2022 06:52 AM
colts0455
Sep 2, 2015 12:41 PM
karpetcm
Aug 14, 2015 03:02 PM
asilomar244
Jul 12, 2015 05:53 AM
Fastbird93
Jul 11, 2015 04:37 PM
