Would an overly crappy exhaust cause more heat?
Old May 28, 2006 | 04:21 PM
YARDofSTUF's Avatar
My car runs kinda hot(I think) Like 220-240 idling for a long time, fan works, outside temp today is 84 degrees.
I've only got a 305 tbi, exhaust was a cheap one a texaco garage put on.
Old May 28, 2006 | 07:34 PM
teke184's Avatar
Re: Would an overly crappy exhaust cause more heat?
no...
your radiator is either clogged, or your waterpump is going out.
Old May 28, 2006 | 10:15 PM
YARDofSTUF's Avatar
Doubt its the radiator, temps have been like this for a while, think I've had it flushed 2 times since its started to be hot.
Is replacing a water pump fairly easy for an idiot?
EDIT: I'll have to drain the coolant for that right? SOunds like a good time to add a 160 thermostat, or not worth it?
Old May 28, 2006 | 10:27 PM
Dave89IROC's Avatar
umm........
220-240 is normal for a 89 TBI f-bod, the fan doesn't come on till 230-235
I had a 87 regal t-type fan switch in mine, turned the fan on at about 210-215
Old May 28, 2006 | 11:12 PM
YARDofSTUF's Avatar
Originally Posted by Dave89IROC
umm........
That saves some time I guess lol
I just dont remember it being that hot before.
Old May 29, 2006 | 10:53 PM
brians96Z's Avatar
My 90 L03 Camaro runs 220-240 in 80-90 deg. weather, when idiling for very long. Out on the highway though, normal operating temperature is around 195-200 degrees. I would say our cars are normal. I think it is the nature of the L03 to get pretty hot at times.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ro2207
Dec 4, 2014 06:18 PM
cristian1311
Nov 23, 2014 02:22 PM
