SES, no cags and reverse lockout
Old May 27, 2006 | 02:38 PM
chrisn's Avatar
on my '95 z28 M6 ive got an SES light, my skip shift light comes on but the solenoid does nothing, and my reverse is hard to get into. ive changed the #6 fuse two times and both times it blew as soon as the ignition switch is turned. dont know where to start with this one. ill be doing more reaserch myself but any extra help would be appreciated.
thanks
Old May 27, 2006 | 03:56 PM
moparman's Avatar
Re: SES, no cags and reverse lockout
First thing is get the SES code pulled, then post the exact number.
Old May 27, 2006 | 08:03 PM
There are several different things on the #6 circuit in the 95's, including:
-skip shift solenoid (why do you want it to work )
-reverse lockout solenoid
-EGR vacuum solenoid
-EVAP purge solenoid
-O2 sensor heaters
-cooling fans
You need to identify which of the above is blowing the fuse. Shoebox has the 95 wiring diagrams on his Tech Pages.
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
Old May 27, 2006 | 08:35 PM
chrisn's Avatar
yea, i will definately get someone to pull those codes tommorow. would/could a burned o2 extension grounding out somewhere cause this?
Old May 27, 2006 | 11:52 PM
Sure... shorting the +12V wire in the O2 sensor to ground would certainly blow the fuse.
Old May 29, 2006 | 05:18 PM
chrisn's Avatar
alright here are the codes i pulled...
13 left o2 sensor
26 ODM fault ccp circuit
27 ODM egr circuit
34 MAP sensor signal (low voltage)
63 right o2 sensor
77 ODM fault fan 1
83 ODM fault reverse inhibitor
84 CAGS
ill hopefully be able to get under the car here tonight to check on those o2 extensions.
Old May 30, 2006 | 12:01 PM
chrisn's Avatar
i got it fixed. it was just a burnt o2 extension.
blac94Z
Nov 4, 2015 01:59 PM
94Maroz28
Oct 27, 2015 04:38 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
