Shifter Problem???
Old May 24, 2006 | 04:35 PM
90tealindy's Avatar
Shifter Problem???
I noticed my shifter is able to twist left and right. I'm not sure if it's just loose or if it's supposed to be able to do this or what. I also noticed that the shifter is able to be pulled up about one or two inches. Is this normal? If not, what do I do to fix it? It's on my 97 five-speed Camaro. Thanks for any input.
Old May 24, 2006 | 09:36 PM
90tealindy's Avatar
Re: Shifter Problem???
How do I go about doing that?
Old May 25, 2006 | 07:26 AM
97FormulaWS-6's Avatar
Sounds to me like the stick broke loose from the rubber isolator in the shifter. Got to either upgrade with a new shifter, head to the junk-yard and get a replacement; or see if u can find a replacement shaft w/o the isolator on ebay.
Old May 25, 2006 | 03:37 PM
90tealindy's Avatar
Well the shifter has been like this pretty much the whole time I owned the car (about a year). Could it still shift and be broken at the same time?
Old May 27, 2006 | 08:16 AM
90tealindy's Avatar
bump
Old May 27, 2006 | 09:16 AM
yup.
Old May 27, 2006 | 09:52 AM
Bayer-Z28's Avatar
When I went to replace my stock stick I noticed that I was missing a bolt on the T56. It shifted fine, just had some play.
I'm Not exactly sure how to get the center console apart on that model. But it should just lift off. If it doesn't, don't force it. Try to pull the shifter boot over to once side to see how it is held in there. Once you get the shift boot off, you're more than half way there. It's self explanitory after that.
Old May 27, 2006 | 08:02 PM
90tealindy's Avatar
I'll have to look at it tomorrow. I also have to figure out why my ses light came on tonight...
RUENUF
Mar 13, 2016 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
mattstrike
Mar 11, 2015 07:33 PM
karpetcm
Feb 9, 2015 09:21 PM
tds1213
Nov 27, 2014 12:55 PM
