Accel Gen 6 Users...Got a question.
Old May 24, 2006 | 04:13 PM
leadfoot94's Avatar
Exclamation Accel Gen 6 Users...Got a question.
Has anyone here managed to get the stock gauges to work along with installing the Gen 6?
Or does anyone know how to piggyback the ECU so i can retain the stock gauges?
Old May 25, 2006 | 07:34 AM
Re: Accel Gen 6 Users...Got a question.
Which gauges? Oil press, volts, colant temp and fuel level are not interfaced to the PCM. Your Gen 6 should have a tach output. That leaves you with the speed as the problem. You would need to interface the VSS directly to the speedo, perhaps using something from Dakota Digital:
http://www.dakotadigital.com/index.c...cat/cat287.htm
I run a MoTeC, and my solution to the speedo was to simply keep the stock PCM in place. I also paralleled or duplicated several sensor outputs to allow the stock PCM to control the idle speed (the MoTeC I have will not interface to the stepper type IAC motor) and emissions functions like AIR, EGR and EEC purge.
93 RedBird
Nov 15, 2015 08:24 AM
Z Power
Sep 19, 2015 11:19 PM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 15, 2015 11:53 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
