OBD1 Question
Old May 17, 2006 | 02:21 PM
Honda Hunter's Avatar
OBD1 Question
OBD1 cars I'm told cant shift past 7100 because of the computer I'm told. My question is what happens if you do go past that limit? Will it through a code? What exactly happens?
Old May 18, 2006 | 11:07 PM
coletrickle350's Avatar
Re: OBD1 Question
Well, if your opti dosnt fly apart, then the motor will probably not supply fuel or spark to the motor. The PCM has no idea what to do as the tables do not go that high.
Old May 19, 2006 | 05:30 AM
SABLT194's Avatar
Re: OBD1 Question
Some where in the 7000 to 7300 range, the PCM simply shuts down. This kills all ignition and fuel and the motor will obviously just quit. It takes a "key off" then "key on" to reset the PCM. It's kinda embarassing when this happens at the track. Don't ask me how I know
Steve
Old May 19, 2006 | 01:07 PM
BlackScreaminMachine's Avatar
Re: OBD1 Question
If you need to spin it that hard thats when you move onto a stand alone management system, and a ignition system that turns the opti into a pointer and takes the spark out of it.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
