LS1 MAF on LT1 Engine
Old May 8, 2006 | 03:46 PM
Dfetter84's Avatar
Has anyone ever done this with bad characteristics?good?
Old May 8, 2006 | 04:01 PM
Re: LS1 MAF on LT1 Engine
Replacement GM MAFs are the same part number for both cars.
Old May 9, 2006 | 07:13 AM
Dfetter84's Avatar
what if it was a granatelli maf. same concept?
Old May 9, 2006 | 07:16 PM
wyldcdn's Avatar
dumb question
what about a MAF from a 6.0?
same # larger? Any gains?
Old May 10, 2006 | 07:02 AM
97FormulaWS-6's Avatar
Check the P/Ns, if it's the same P/N then they are interchangable. If they are different don't use them; most likely the flow curve (Airflow Vs frequency); which is what your PCM sees to read the airflow is different.
The only way to make it work would be to have the correct flow curve/table and modify/adapt the curve for the LT1 PCM, and have the correct pigtail.
Old May 10, 2006 | 07:32 AM
Dfetter84's Avatar
well the pigtail is the same on MAF's 94-02 but i cant find a P/N on this Granatelli POS,
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
