How to install shift light??
Old May 4, 2006 | 11:38 AM
dubbsix's Avatar
Anyone have any suggestions on where and how to mount a shift light in a 93Z28? Pics would be great!
How hard is the install?
Old May 4, 2006 | 08:47 PM
Bud M's Avatar
Re: How to install shift light??
Install is easy. There are 3 wires. 12v switched, ground, tach. I mounted my light at the base of the A pillar with velcro and ran the wire in through the fuse panel cover on the side of the dash. You can find a switched 12 v source and ground under the dash. I ran the tach wire through the firewall and hooked into the pink/black coil wire.
Old May 4, 2006 | 11:33 PM
dubbsix's Avatar
Oh thats exactly how i want to mount mine. How did you know which wire was 12v switched under the dash?
Old May 4, 2006 | 11:59 PM
HardcoreRM125's Avatar
Hey just curious, what brand light is that? I want something tiny like that maybe even smaller.
Old May 5, 2006 | 01:49 AM
Bud M's Avatar
Sorry, I don't remember what wire I found 12v switched on, but basically I just poked around under the dash until I found what I needed.
The light is an MSD light.
Old May 5, 2006 | 02:11 AM
CustomSSI's Avatar
I think the smallest ones out there are the Raptor Performance ones..... Check them out on our site, there pretty dang small.........
Old May 5, 2006 | 02:37 AM
Sparkz28ss's Avatar
I put mine in the air vent ........its out of the way....and it blinds the crap out of the cars on my left
Old May 5, 2006 | 03:39 AM
Lower's Avatar
Yep, my Harlan Shift Light is in the left most vent of the 3 vents in the center of the dash.
Works great.
Old May 5, 2006 | 04:06 AM
dubbsix's Avatar
I had seen a few pictures of them mounted in the air vent and thought that was really cool. Anyone have any pics of the tach wire location?
Old May 6, 2006 | 04:48 PM
No problems running them through there though with the heating & AC and stuff? That would be awesome cause it wouldnt stand out and look real tacky
Old May 6, 2006 | 09:06 PM
Lower's Avatar
I can't see the heat or cooling of the cars heater or A/C being any hotter or cooler than the heat on the dash of a closed car on a hot sunny day, or the cold on a gloomy winters night.
Old May 7, 2006 | 10:12 AM
atljar's Avatar
Mine is also in the vent with no ill effects. I had a bunch of issues with the Harlan shift light and poor customer service, so I bought a Raptor performance. Its smaller than a roll of quarters, very bright, and works
You can also grab your tach signal at the ECM. Pin 13. red connector. It should be a white wire and just T into it.
Old May 7, 2006 | 12:28 PM
There's a source of switched +12V power right in the fuse box at the end of the dash. Theres a small rectangular opening labeled "IGN". Put a 1/4" female spade connector (Radio Shack) on the wire and push it onto the lug in the fuse block.
Jason Short
Jan 19, 2015 06:34 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
