K&N Oil Filter: Low pressure???
Old Apr 26, 2006 | 10:21 PM
450HP_V6's Avatar
Hi again, 1998 3.8l V6.
Ok, when i changed my oil a while back, i opted for a K&N oil filter because...well to be honest, because it was "K&N" lol. The statistics on the box are rated pretty high (probably compared to some generic "valu-mart" brand), but the thing that cought my eye the most was the part that said
"2x the filter surface area than other leading brands". So I changed the oil and filter, and noticed a pretty big drop in oil pressure. The gauge normally read about half way wich i think is about 30, but after the change, the gauge read about 15 (about a quarter the way up). I dismissed it considering that the pressure was probably low because of the high flow rate that the filter has. Aparently I was right because I've driven over the 3000 miles on the thing before without a single problem. When I most recently changed my oil, I switch filters over to the PURE-One 100k+ brand, and the pressure went back up to normal. I've actually done this twice (switching from K&N to another) with the same results, and the question i have though is, is this low pressure thing no big deal? Or, do you think its really not supposed to do this?
I've changed the oil filter on my '04 dodge stratus R/T, and the oil pressure went down in there a little bit too, but nothing like in my camaro. Just looking for some quick advice. Thanks again!
http://www.knfilters.com/oilfilter.htm, "OUR OIL FILTERS HAVE NUTS!"
Old Apr 27, 2006 | 08:14 AM
GRNcamaro's Avatar
Re: K&N Oil Filter: Low pressure???
there was a test done by a guy on the corvette forum about filters the k&N not included in this test and said there was little to know diffrance in filters ALTHOUGH i think the k&n would be a lot diffrant i havent used one i use fram filters a guy at my job uses them on his STI and swears by the K&N air and oil filters. but i would speek to one of the guys that has experince with this product.
Old May 2, 2006 | 06:00 PM
450HP_V6's Avatar
Okie Dokie
Old May 3, 2006 | 08:00 AM
Demon's Camaro's Avatar
If I was you I would just stick with the stock replacements, the FRAM filters are very very poorly made so do not use those.
Old May 12, 2006 | 04:10 PM
PaganEgyptian's Avatar
Post Re: K&N Oil Filter: Low pressure???
Ditto. I use either AC Delco or WIX. When I go AC Delco, I opt for a PF-52.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
BigWil
Mar 29, 2015 12:24 PM
