How to tell if keyless remote is broken
Old Apr 26, 2006 | 03:20 PM
Jazsun's Avatar
I just got this car which has keyless entry but it does not work. I replaced the battery in the one I have, and then tried programming it and the car would not respond when I held the button down for the specified amount of time. Is there any other way to test if the remote is broken before I buy another one for $40?
Old Apr 26, 2006 | 03:25 PM
MeanGreen97Z's Avatar
Re: How to tell if keyless remote is broken
Try taking the board out and cleaning the contact pads and switches with rubbing alcohol and a q tip. It fixed mine.
Old Apr 26, 2006 | 03:33 PM
lantern's97Z's Avatar
Take the board out and wash it with warm soap and water let air dry and should be good as new. You can wash any kind of board. I do it all the time with copiers and works great for tv remotes.
Old Apr 26, 2006 | 03:52 PM
Bad idea... corrosion will set in... dont wash it with water. Use rubbing alcohol.
Old Apr 26, 2006 | 04:19 PM
Jazsun's Avatar
I already scrapped them a little w/ a screwdriver when I had it apart to put the bat in. They didnt look bad at all. Guess I can try and clean it agian. I am just afraid if I buy a new remote that it still wont work and something is wrong w/ the transmitter. I have a strong feeling its not the remote.
Old Apr 26, 2006 | 04:23 PM
Check your fuses...
Old Apr 26, 2006 | 04:28 PM
Jazsun's Avatar
Originally Posted by MeanGreen97Z
Check your fuses...
IS there a specific fuse for keyless entry? I didnt see one under the hood or inside.
Old Apr 26, 2006 | 07:35 PM
Jazsun's Avatar
ne 1?
Old Apr 26, 2006 | 08:40 PM
Dave89IROC's Avatar
what year?
Old Apr 27, 2006 | 05:21 PM
JimboManJones's Avatar
Did you put the switch board back in the right way? I know I messed up on mine, and it wouldn't work until I flipped the switch board back over, dumb mistake but hey would be an easy fix.
Old Apr 27, 2006 | 05:40 PM
Jazsun's Avatar
Its a 96, I tried nail polish remover on the contacts (had no rubbing alcohol) and soaking the board but nothing helped.
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
