Is there anything I can do to stop the tranny from rattling in neutral?
Old Apr 22, 2006 | 12:42 AM
speed_demon24's Avatar
My transmission rattles in neutral when I don't have the clutch pushed in. I tried replacing the TOB when I replaced the clutch disk, but that didn't do anything. As soon as the clutch is completly disengaged in neutral the noise goes away. Is there anything I can do to stop the rattling besides having the clutch in all the time? Its kind of annoying
Old Apr 22, 2006 | 09:19 AM
Hawk's Avatar
Re: Is there anything I can do to stop the tranny from rattling in neutral?
Stock mine made noise to. I got a streettwin setup that came with a new TOB and it still made noise. I've learned to live with it, I think it's fairly common/normal for a M6 car unless your talking REAL loud.
Brian
Old Apr 27, 2006 | 01:29 AM
It's pretty damn loud. I can it outside the car with no problem... Non of my friends cars do it either. The tranny shifts fine, but the rattling in neutral is annoying as hell and embarassing.
Old Apr 27, 2006 | 11:44 AM
93redBirdMan's Avatar
its probably a bad motor mount or tranny mount... go under there and take a peek
Old Apr 27, 2006 | 11:47 AM
I have poly motor and tranny mounts in, and they are fine, and I don't see how they would make the transmission rattle.
Old Apr 27, 2006 | 11:57 AM
DontMixWithRice's Avatar
pilot bearing?
Old Apr 27, 2006 | 05:39 PM
Jazsun's Avatar
Mine does same thing, and its loud as hell I can hear it ouside the car and it does it in low rpms. No clue. Read my thread in the drivetrain forum.
Old Apr 27, 2006 | 06:48 PM
anaik's Avatar
I heard once that if there's a rattle with the clutch pedal in, it's the TOB. If it rattles with the clutch pedal out and in neutral, it's the input shaft bearing.
Never had the problem, so I don't know if true or not.
Old Apr 27, 2006 | 07:54 PM
onebadponcho's Avatar
While those bushings won't make the transmission rattle, they can make the rattle in the transmission louder, due to the harder polyurethane bushings transmitting more of the vibration/sound to the body of the car. Mine has the same rattling sound and I'm sure a lot of other 6 speed F-bodies do also......
Old Apr 29, 2006 | 04:02 PM
wrd1972's Avatar
I put a brand new round bearing in once, it was ver loud.
I then put in the square Corvette TOB and its dead silent. It must be better quality.
Old Apr 29, 2006 | 08:38 PM
matt65's Avatar
Mine Rattles too. Same thing you are describing.
Old Apr 29, 2006 | 08:51 PM
Stoopalini's Avatar
You are probably hearing the throw-out bearing rattle against the fork due to no pressure being on the fork.
Mine has always done this. I've had a stock pressure plate and bearing, a SLP LT4 setup, and now a SPEC, and they've all done this; most likely because most PPs are Valeo units.
Maybe the square corvette bearing is narrower in the fork channel, and this is why it's quieter? Sure would be nice if an aftermarket company came out with a TOB which would eliminate this noise.
Thomas.
Old May 1, 2006 | 12:08 AM
Thomas.
I thought it was this too so I tried pushing the clutch pedal in a little but, and it doesn't do anythink, it stops when the clutch is completly disengaged.
Old May 1, 2006 | 04:22 PM
Jazsun's Avatar
same here its wierd
dylan1303
May 22, 2015 12:24 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
squarehead
Nov 21, 2014 08:02 PM
