Grease Question
Old Apr 21, 2006 | 05:31 PM
YARDofSTUF's Avatar
Grease Question
Ok, at the end of the nice summer weather last year I installed a new adjustable panhard rod with ALOT of help from you guys, nice weather has started and now i'll get to drive it, buit the instructions said to give it 2-3 shots of a silicon based grease. Well i've had the grease gun for a while and today I went to look for grease that fits it. The only grease I found in a cartridge form was marine grease. It doesnt list what is in it, so I need to know if marine grease is ok to use.
Thanks!
Old Apr 21, 2006 | 05:36 PM
2001NBMZ28's Avatar
Re: Grease Question
That's what I use, every oil change.
Old Apr 21, 2006 | 05:40 PM
YARDofSTUF's Avatar
Re: Grease Question
So I should add a few squirts every oil change?
I should probably learn how to change my own oil lol
Old Apr 22, 2006 | 08:40 AM
2000GTP's Avatar
Re: Grease Question
I ordered the silicon based grease directly off of the Spohn website and bought a seperate grease gun as well. I don't take chances after all the money that has been spent on just suspension parts. www.spohn.net
Old Apr 22, 2006 | 10:39 AM
YARDofSTUF's Avatar
Re: Grease Question
http://www.spohn.net/category.cfm?categoryid=1057
That one?
Old Apr 22, 2006 | 10:44 AM
2000GTP's Avatar
Re: Grease Question
Originally Posted by YARDofSTUF
Yep, thats the stuff.
Old Apr 22, 2006 | 10:51 AM
YARDofSTUF's Avatar
Re: Grease Question
You got the grease gun there too? I cant find it in the links.
Old Apr 22, 2006 | 12:06 PM
2000GTP's Avatar
Re: Grease Question
No, I bought the grease gun from Auto Zone. You can get those just about anywhere.
Old May 5, 2006 | 11:10 AM
YARDofSTUF's Avatar
Re: Grease Question
Ok now I have the grease in the gun, tried quirting it and it didnt come out, does it only work when its on the little "nubby things" Will it ooze out a little?
Thanks.
Old May 5, 2006 | 02:04 PM
2000GTP's Avatar
Re: Grease Question
Maybe you dont have the cartridge set up right in the gun. It should squirt regardless of whether it is connected to the "zerk" fitting or not.
Old May 5, 2006 | 02:08 PM
YARDofSTUF's Avatar
Re: Grease Question
Ah, ZERK!
Well I pushed it into the zerk fitting and it seems to have worked, theres a little bit on the tip of the zerk.
The grease had an arrow pointing to one end and it said towards gun head and I removed the seal, stuck it in.
97TA-WS6-Con
Feb 1, 2015 01:01 PM
squarehead
Jan 15, 2015 07:02 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Duke
Aug 6, 2002 07:53 PM
