Intermediate problem with A/C compressor not turning on
Old Apr 20, 2006 | 10:49 PM
speed_demon24's Avatar
Sometimes when I start my car and turn the A/C on, it blows air but the compressor doesn't kick on. Then if I turn my car off then on again, it kicks in. And the A/C in my car blows colder than the other 4 cars at my house too. I've had my car for 3 years now, and it's been doing this for about a year now, i've just been too lazy to fix it. I'm guessing its just a bad sensor in the system or something.
Old Apr 20, 2006 | 11:04 PM
n2ceptor's Avatar
Re: Intermediate problem with A/C compressor not turning on
Could be the clutch cycling switch....
Old Apr 21, 2006 | 01:42 AM
Well its fine if it works the first time when i try and use it if the cars running. I can turn it on/off without any problems, it's just when it doesn't work the first time, it wont work unless i turn off and start my car again. The clutch engages,disengages fine when its running.
Old Apr 21, 2006 | 09:26 PM
deputydough's Avatar
mine sort of did the same thing last summer. except it would not always work after restart. i beat my self up for a month before i broke down and took it to the dealer. the wires going into the compressor had broken and would sometimes make enough contact for it to work. they wired up another connector and it works now. would not hurt to look at it anyway.
Old Apr 21, 2006 | 09:35 PM
Hawk's Avatar
i had the same problem. I was low on refrigerant, you might just need a recharge. THe compressor won't turn on unless the pressure sensor senses enough pressure. When your on the border of enough refirgerant, it will be intermittant when your compressor comes on.
Brian
Old Apr 22, 2006 | 12:38 AM
Brian
Could it be a bad pressure sensor, because its been doing it for a year now, and if I had a leak it would be out of coolant by now, and the A/C blows cold as hell...
Old Apr 22, 2006 | 07:26 AM
Hawk's Avatar
could be a bad switch. YOu can always jumper the switch out to test it.
Brian
liamcg97
Nov 25, 2019 05:55 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
