quick rear end gear question
Old Apr 19, 2006 | 12:50 PM
68birdls1's Avatar
hey guys, i am pretty sure the answer is yes, but i wanted to make sure before i went ahead and bought'em. but are the rear gears from a ls1 work in a lt1 and vice versa? thanks alot
daniel
Old Apr 19, 2006 | 01:03 PM
MyShibbyZ28's Avatar
Re: quick rear end gear question
Yes.
teke184's Avatar
yes sir...
even the 3rd gens will work.... except the ausi rear...
Old Apr 19, 2006 | 08:41 PM
68birdls1's Avatar
thank you very much guys. i was pretty confident that they were but i just wanted to make sure. yall take it easy and thanks again
Old Apr 19, 2006 | 09:18 PM
Of course you need to verify that both cars have the same "series" carrier, or the gears will not swap.
Old Apr 20, 2006 | 07:26 AM
68birdls1's Avatar
now by series you mean that they are 7.5"?!?
Old Apr 20, 2006 | 07:31 AM
No... "series" related to the spacing of the ring gear in the carrier. If a car left the factory with 2.73 gears, it will have a 2-series carrier. If it left the factory with 3.23 or 3.42 gears, it will have a 3-series carrier. You can't put gears from a 2-series carrier in a 3-series carrier. You could put gears from a 3-series carrier in a 2-series carrier with a spacer, but that's not the best way to do it. If you want to put anything higher than a 3.08 in a 2-series carrier, you need to get a special, wider gear. If you want to put a 3.23 or higher numerical gear in a 3-series carrier, you are good to go.
Old Apr 20, 2006 | 12:35 PM
68birdls1's Avatar
ok i gotya. so unless the 2.73 original car got aftermarket 3.42 gears then i cant use'em. thanks alot
oldschool
Feb 9, 2016 09:21 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
