A/C Cooling Fan
Old Apr 17, 2006 | 04:38 PM
Ragtop-87's Avatar
A/C Cooling Fan
Here is my problem. I have a 87 Camaro 305 TPI. I have dual fans on the car and when I turn the A/C on one of the fans are suppose to run. But It don't. I have checked the fuses, I have swapped the wires around and the fan does work, so that tells me that the motor is not bad. Has anyone got any suggestions on what the problem might be. Thanks
Old Apr 19, 2006 | 03:28 PM
1987IROC350's Avatar
Re: A/C Cooling Fan
It sounds like a fan relay. Little black box about 2.5 inch by 1.2 inches. If you need to see a picture go to e-bay and type z28 fan relay. They are about $10 usually. Just make sure you gat the same part number because the driver side and pass. side fan have different temperature fan on times.
Old Apr 19, 2006 | 07:21 PM
Ragtop-87's Avatar
Re: A/C Cooling Fan
Thanks, but I don't think that we are talking about the same relay. The one I am talking about comes on as soon as I turn on the A/C. It don't matter what the temp is. The fan that is not coming on is on the passenger side.
Old Apr 20, 2006 | 12:32 AM
Gord's Green Z28's Avatar
Re: A/C Cooling Fan
1987 cars turned the passenger side fan on with temp only. 1988-92's had the temp and/or AC high pressure turn on the fan.
Driver side is turned on by temp and A/C.
Old Apr 20, 2006 | 12:39 AM
89_Irocz's Avatar
Re: A/C Cooling Fan
Is there 2 diff. relays for the 2 fans?
Old Apr 20, 2006 | 11:06 PM
Re: A/C Cooling Fan
Yes. On my car the primary fan (driver side) relay is next to the radiator cap, Held in by two plastic screws.
The secondary fan (passenger side) is on the passenger front quarter panel.
Look for relay # 14089936
warmeck
Jun 5, 2015 05:19 PM
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
