calling Cartman!!!
Old Apr 16, 2006 | 03:27 AM
snakeatinZ's Avatar
calling Cartman!!!
Josh, What did you say to do with a steel driveshaft to beef it up? Something about welding this or that??? I deleted the pm on accident.
Thanks man.
Steve
Old Apr 16, 2006 | 10:48 AM
Josh'95Z28conv's Avatar
Re: calling Cartman!!!
Thanks man.
Steve
I had the slip yolk welded because it was leaking tranny fluid out the center. It didnt make it any stronger or anything. I had it balanced, and straightened. It had .010" of runout I believe, which weakens it a bit. Also have the u joints replaced. The stockers are plastic injected to hold them, instead of having snap rings. The stockers can also be off in alignment.
They told me the stock shaft in good shape will hold 400-500 HP. So just have new u joints installed, check for runout, balance, and have the slip yolk welded if its leaking. Then you're good to go.
Old Apr 17, 2006 | 05:11 PM
snakeatinZ's Avatar
Thank You Josh!!
Steve
Jeff1904
Jun 5, 2016 05:00 PM
LT14LIFE
Nov 15, 2015 06:22 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
drt
Sep 27, 2015 04:39 PM
