drive shaft
Old Apr 15, 2006 | 11:59 PM
runninfromthelaw's Avatar
drive shaft
stock lt1 or ls1 whats stronger for drag racing?
Old Apr 16, 2006 | 12:26 AM
teke184's Avatar
Re: drive shaft
steel lt1 shaft is stronger...
Old Apr 16, 2006 | 10:06 AM
97FormulaWS-6's Avatar
Re: drive shaft
Steel shaft is defenetly stronger.
Old Apr 16, 2006 | 10:31 AM
Honda Hunter's Avatar
Re: drive shaft
Another vote for steel. Cant remember the limit of the aluminum though.
Old Apr 16, 2006 | 10:46 AM
CMANZ28's Avatar
Re: drive shaft
I just put on a LS1 aluminum driveshaft on my car....old one is forsale if you want to buy it!
Old Apr 16, 2006 | 10:48 AM
Re: drive shaft
Why would I need two steel driveshafts on the same car?
Old Apr 16, 2006 | 03:27 PM
Re: drive shaft
If I were to buy a steel DS; it would NOT be stock.... no way.
If your stock steel one doesn't vibrate, use it. If you want a cheap replacement that might solve a minor vibration issue; try a 1LE or LS1 shaft.
If you want to not risk anything and have a shaft that you don't have to worry about go with a Chromoly shaft like a Denny's NR shaft which is what I run.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
