6 sp pops out of reverse
Old Apr 13, 2006 | 10:27 PM
BrownEyedZ28's Avatar
When ever i put it n reverse it pops out and i have to keep putting it back in.. i know it probably needs rebuilt, will i have to have it all done or can they just fix the reverse? I have called around and cant find any place that works on standards...
Old Apr 14, 2006 | 12:57 PM
Re: 6 sp pops out of reverse
Again, you need to review the guidelines for posting. There are specific forums for many types of info.... this one belongs under "Drivetrain", not Advanced Tech. I'll move this to the "Drivetrain" forum for you.....
Old Apr 15, 2006 | 05:41 PM
swemdog's Avatar
its most likely because the synchronizer for the reverse gear is worn down. If its just the blocker ring its a cheap part to replace, if its the whole synchronizer assembly then its going to be more. The reverse gear is one of the first things you will see when you take the transmission apart and you don't need to disassemble the whole trans to replace the synch. (unlike 3rd gear , ask me how i know) Where are you located?
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
PopoFormula
Oct 12, 2015 04:19 PM
Toxintwins
Sep 11, 2015 11:13 AM
