procharger users - pcv lines help
Old Apr 11, 2006 | 10:01 AM
hulettsz28's Avatar
I removed the pcv line from the valve cover to the throttle body, and vented it to the atmosphere. Where is the pcv line on the intake manifold, and what needs to be done to it? Thanks
Old Apr 12, 2006 | 08:03 PM
97WS6Pilot's Avatar
Re: procharger users - pcv lines help
It runs from up under the throttle body to the driver side of the intake manifold. It pulls blowby from the lifter valley. I leave mine stock.
Old Apr 13, 2006 | 11:29 AM
guardrail's Avatar
I replaced my filler cap with a breater, and left the PCV hooked up stock. I capped the other line running from the TB, however I'm still getting a little oit out of the breather. Can a bad pcv cause that? Is there any other way to get boost into the block? ATI says to hook up the PCV to the maf pipe on the suction side of the blower.
Old Apr 13, 2006 | 01:30 PM
97WS6Pilot's Avatar
ATI's procharger manual says just what you said. However there is not enough vacuum present to be effective. I would get foul odors at stop lights when I had it plumbed like ATI suggests. Also my oil would have to be changed more often due to all the harmful contaminants in the blowby.
The Pcv is a one way check valve so boost will not leak into the lifter valley unless the valve is defective. Some people have used brake booster check valves but I don't think its necessary.
As far as the breather hose, I've tried it all different ways. The best solution I've found is to run it to the suction side of the blower with a air compressor water separater inline. About once a month I must empty oil from the separater into the crankcase.
Old Apr 13, 2006 | 04:34 PM
-vellu's Avatar
Are you using modification like this?
http://www.projecttransam.com/projects7.asp
Old Apr 13, 2006 | 06:13 PM
97WS6Pilot's Avatar
Yes, except mine is a Campbell Hausfield and I did not drill the holes like he did. I bought mine at lowes as well as the 1/2 inch threaded copper pipes that my breather hose fits so well over.
Old Apr 14, 2006 | 12:49 AM
-vellu's Avatar
Thanks! I will make that one too.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
