How Dangerous is N20?
Old Nov 5, 2002 | 03:58 PM
Jake77444's Avatar
If I got rear ended real bad and my N20 was in the back hatch? How dangerous would this be? Would by car explode into flames? Thats probably the only thing holding me back at this point.
Old Nov 5, 2002 | 06:59 PM
gb95zconv's Avatar
No, its non-flamable. The worst thing that could happen is the bottle could be knoked loose and hit you in the head...ouch.
As an oxidizer its safer than oxygen as it requires alot of heat to break it down into oxygen and nitrogen
Old Nov 5, 2002 | 09:05 PM
LS1C5's Avatar
But in the case that you do get rear-ended you should get out of the car and run as fast as you can while yelling "NAWWSSSSS!"
Old Nov 6, 2002 | 04:29 PM
rpm4lalo's Avatar
Nitrous oxide is not for amatuers!
I've seen the way you drive, you have a heavy foot.
You'll blow yourself up.
---Harry, Racer's Edge
Old Nov 9, 2002 | 04:58 PM
Jake77444's Avatar
lol harry, you've seen the way I drive huh? When was this lol.
Old Nov 9, 2002 | 05:40 PM
oil pan 4's Avatar
First of all I never get tired of people sh*ting on that movie .
Nitrous Oxide is an oxidizer but decomposes onto Oxygen and Nitrogen @ 617'F
If you don't want the bottels to get crushed incase of rearend hit put the
(yelling) "NAWWSSSSS!"
on the fuel and wheel hump in the back not down in the hatch part.
It would be hard to crush one of them and not to easy to puncture one eather unless your getting shot at, if so then
and watch your car blow up .
I think the 10 gallons gasoline in your flimsy steel fuel tank is more dangerous than 1100 psi of Nitrous Oxide in a bottel that will burst at around 3500psi and is normaly closed and some times not even in there.
Cbr02
Aug 24, 2015 07:12 AM
MattFick
Feb 15, 2015 10:16 PM
T/A lt1
Oct 10, 2002 03:14 PM
96z
Sep 19, 2002 10:45 PM
phoenix916
N2O Tech
Jul 29, 2002 05:21 AM
