4L60E? problems...
Old Mar 23, 2006 | 11:24 PM
uh-oh_LT-1's Avatar
4L60E? problems...
ok well i just bought a 93 Z28 and it only has 1st and reverse. i knew the previous owner and at first it just lost 2nd and then a couple weeks after that 3rd and 4th went with it. it has the stock tranny which i thought was a 4L60E but he says its a 700R4. ive heard that it may just be the cylinoids but ive also heard it could be the valve body. any ideas would be nice. thanks!
Old Mar 24, 2006 | 02:57 AM
Pro Built Automatics's Avatar
Re: 4L60E? problems...
It is a 700R4 (4L60), and it needs to be rebuilt. What are you looking for, in terms of a transmission? Torque converter?
Old Mar 24, 2006 | 07:56 AM
MeanGreen97Z's Avatar
Seals in the valve body and the bands.... maybe clutches and steels also. I'd get a nice rebuild kit and have someone build it for you if it's just a bolt on car. If you need power look to many of the good transmission builders out there.
Old Mar 24, 2006 | 12:21 PM
uh-oh_LT-1's Avatar
well since it needs to be rebuild i think im gonna find a good builder and keep the 700R4. i do plan on runnin it sometimes but its gonna be an everyday driver too so i think im gonna go with around a 2800 stall converter.
Old Mar 24, 2006 | 10:37 PM
12SCNDZ's Avatar
Where are you located? We're in Maryland, but we ship stuff nation wide. Give me a call, maybe we can help you out. 302-250-1202.
www.cahallperformancetransmissions.com
Thanks,
Frank
CPT
Old Mar 24, 2006 | 11:14 PM
uh-oh_LT-1's Avatar
Thanks,
Frank
CPT
Im in South Jersey. I can get down there to drop off n pick up the tranny. I'll deffinately be calling tomorrow if you're open and if not you'll be hearing from me on monday!
Old Apr 2, 2006 | 11:19 AM
uh-oh_LT-1's Avatar
ok well today i went to take off the cover for the governor gear but im not exactly sure where that is. there are 2 round covers in the rear of the drivers side of the tranny. one is bigger than the other and the smaller one has a sheet metal clamp around it. also, should i drain the tranny fluid before i try this?
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
