Procedure For LS1 Rocker Arm Install?
Old Mar 23, 2006 | 08:29 AM
JoeMack's Avatar
Does anyone know the procedure for installing stock rocker arms on an LS1? I thought that you just torque, rotate the motor a few times and then re-check. Now I am hearing that there is a recomended procedure to follow. Thanks
Old Mar 23, 2006 | 04:00 PM
teke184's Avatar
Re: Procedure For LS1 Rocker Arm Install?
all i did was torque them down....roll the motor over a few times....recheck the torque and be done with it.
did it that way when i did my spring swap with stock rockers, and later when i installed my harland sharp rollers.
Old Mar 26, 2006 | 09:27 AM
smallblock458's Avatar
Do the Harland Sharp's fit under the stock V/C's or did you have to modify anything?
Old Mar 26, 2006 | 09:45 AM
teke184's Avatar
they were the stock 1.7 ratio...not the 1.8s.
but yes they fit.
had to use a hand file to clearance a TINY bit of the inside egde of the cylinder head, where the valve cover seals to the head.
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
