Need Gen 7 Help
Old Mar 20, 2006 | 10:34 PM
Schurters LT1's Avatar
Need Gen 7 Help
I need help with hooking up my dual sync for the gen 7...95 LT1
I have the fast track harness,
Accel plug and play Y connection
Accel dual sync Dis..
right now i am lost, as to where the wires go from the gen 7 box, to the 8 pin
accel Y conection and then to the dual sync.....
any tips would be great
thanks
Old Mar 20, 2006 | 10:51 PM
NC-LT1's Avatar
Re: Need Gen 7 Help
I am not sure if your fast track harness is the same as for the vettes, but I would assume it was. I will have to dig out my manual on it, but you should be able to just use the wiring for the dual synch straight out of the schematic for the distributor hook up with the use of the MSD 6a,6al etc CDI box as the ICM. you will be eliminating the use of the factory ignition control module and just wire to the pinout of the accel box using the schematic for the fast track harness to determine which wires they will be.. off the top of my head that is as specific as I can get but will see if I can find a few minutes tomorrow to look it over.
Chris
Old Mar 20, 2006 | 11:07 PM
NC-LT1's Avatar
Re: Need Gen 7 Help
review this as well.. I will continue looking tomorrow for the pin out.
Chris
http://www.rancefi.com/HeavyGraphics...stributors.htm
David Dempsey
Mar 12, 2016 12:42 AM
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
