Ideas why interior lights don't work in '96 WS6?
Old Mar 19, 2006 | 10:44 PM
Turbo6's Avatar
Hey Guys, I've been trying to figure out for a while why my interior lights don't work. Basically, all the dash lights, stereo and headlights work fine. But, when I open the door, or use the **** on the dash to turn on the interior lights, they don't come on. The reading lights won't come on either when I flip the switch on the rear view mirror. All fuses are fine and wiring harness and ground connections are intact. All other electrical accessories work properly.
Someone told me there was a relay under the driver or passenger side dash/footwell having to do with some sort of timer, but I don't know anything about this. Anyone have this problem or have any ideas?
Old Mar 19, 2006 | 10:45 PM
IRONFIST's Avatar
Re: Ideas why interior lights don't work in '96 WS6?
This may seem dumb, but did you check the bulb?
Old Mar 19, 2006 | 10:48 PM
Turbo6's Avatar
It's all the lights. The driver and passenger reading lights in the rearview mirror, the driver and passenger under dash lights, the rear cargo light. The odd part, is the little red lights that illuminate the power window and lock switches in each door still work.
Old Mar 19, 2006 | 10:50 PM
Shockwave's Avatar
Lounge Moderator
Moving to General Tech...
(Might want to check fuses, if you haven't already...)
Old Mar 19, 2006 | 10:52 PM
Turbo6's Avatar
Posted by Turbo6:
Old Mar 20, 2006 | 08:04 AM
Tanaman's Avatar
I have the same problem with my Z, I have been told it is the BCM. I have a new one but haven't replaced it yet to see if that cures it.
Old Mar 20, 2006 | 09:08 AM
Turbo6's Avatar
Thanks for the reply. What is the BCM?
Old Mar 20, 2006 | 01:01 PM
Tanaman's Avatar
Body Control Module
Old Mar 20, 2006 | 05:46 PM
Turbo6's Avatar
Thanks man, I'll look into that. If you don't mind, could you please post as to whether this fixed your problem when you get around to replacing it?
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
thenewkid
Nov 29, 2014 04:54 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
