Power window motor brand preference??
Old Mar 17, 2006 | 07:14 PM
Dwaynez28's Avatar
Question Power window motor brand preference??
Hello, My driver side window only goes down just a little, then it takes several tries, a few minutes apart to go all the way up. Was told it probaly was my window motor going out. Saw in one catalog that the motor was around $130.00. Saw in a J C Whitney and "if i saw it right", at AutoZone it was around $54.00. I E-mailed J C Whitney and was told the motor would fit,but would not automatically go all the way down with one push of the button--would have to hold button down, I can deal with that part--Question is -Do you guys have a preference of window motors as i heard it was a little bit tricky to replace or know of a vendor who sells these cheap and maybe o.e.m.-Kinda want to do right the first time-Thanks Dwayne
Old Mar 17, 2006 | 07:42 PM
Donohue96M6Z28's Avatar
Re: Power window motor brand preference??
i wouldnt want a GM one personally, i would go with a autozone just bc they have a lifetime warranty. by the way, a couple yrs ago, i bought 2 bradn new gm window motors off of here for $60 combined. so $130 is alot to spend on one.
Old Mar 17, 2006 | 07:45 PM
mike 96 ws6's Avatar
The links won't work via copy - paste, so see this thread. I'm username "lectrocrew" on that board.
Originally Posted by lectrocrew
FYI:
If anybody buys their window motor at Autozone, don't get the one manufacterd by Dorman. It uses a bracket that is included, which you don't need, but because of this it does not have all the holes like the GM motor does and the holes needed for installing it like Shoeboxes web page shows are not there.
My AZ had a motor manufactured by Siemens which had the correct holes and fit fine. It has the same AZ part #742-101 as the Dorman motor so you need to specify which one you want.
The Siemens part # is WL42014 but AZ does not use that part #.
94Z28WP's Avatar
I have a window motor from Advance on the drivers side and it's strong and works well... Best thing, if it goes bad it has a lifetime warranty and I drive 2 miles and get another.
Old Mar 17, 2006 | 08:57 PM
Dwaynez28's Avatar
Thanks Guys for the replies/help. Dwayne
Old Mar 17, 2006 | 09:09 PM
Z95m6's Avatar
get the autozones. I replaced mine with an autozone one and it lasted probably 3.5 years. I saved the box and the receipt because i knew it was gonna happen again, so i just exchanged it for a new one and i'm back going for a few more years.
Old Mar 18, 2006 | 11:19 AM
94arcticwhiteM6's Avatar
i used the GM ones mainly cause i get a huge discount on 'em and we have them in stock. so convinient.
Old Mar 18, 2006 | 10:04 PM
jaguar5822's Avatar
I'd go with the Autozone, but that's because I work there But our price for that particular motor is about the best around for a lifetime warranty motor, if it goes bad they don't hassle you, just give you a new one, and since the rivets are replaced by nuts and bolts (included with the new motor) it is much quicker to replace than before, I changed a replacement that had gone bad in 35-45 minutes from door panel off to door panel back on.
James
Old Mar 18, 2006 | 10:07 PM
wrd1972's Avatar
They are all the same, just get one with the lifetime warranty.
Old Mar 18, 2006 | 11:58 PM
Dwaynez28's Avatar
Thanks once again for all your help Dwayne
Old Mar 19, 2006 | 06:03 PM
scottso's Avatar
Originally Posted by Dwaynez28
...I E-mailed J C Whitney and was told the motor would fit,but would not automatically go all the way down with one push of the button--would have to hold button down, I can deal with that part--Question is -Do you guys have a preference of window motors as i heard it was a little bit tricky to replace or know of a vendor who sells these cheap and maybe o.e.m.-Kinda want to do right the first time-Thanks Dwayne
???The express down is handled by a separate module, not the motor. They don't know what they are talking about. If you want them fixed permanently run a separate power source and install relays (posted here several days ago). I did this on the DS - and the window flys. It has so much power now you have trouble holding it back - the way it should be!
It really bothered me having such a powerful car with such wimpy windows.
D1SC383LT4
Jan 1, 2016 01:56 PM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
MilkyClr69
Jul 29, 2002 10:01 AM
