Shifting into 5th w/275/40/17s & 4.10s..help
Old Mar 16, 2006 | 09:48 PM
Showme's Avatar
Hello,
I got the 4.10s installed. They don't wine I started doing the proper break-in for the gears but couldn't take it any longer at 350 miles. So, I go to a disserted road, estimate the 1/4th...then blast off. The tires did spend a little but hooked really well.....BUT, I had to shift into 5th.
What can I do other than going to a 17X11" rim to keep this from happening.
Would going to a 285/40/17 BFG DR in the back solve this?
Other than the concern mentioned above, I really like the gears.
Thanks,
Tim
Old Mar 16, 2006 | 10:02 PM
Bow94z's Avatar
Re: Shifting into 5th w/275/40/17s & 4.10s..help
what are you shifting at?
My stock LT1 with 4:11's i'll cross the line in 4th comming up on the 5th shift on 275/40/17
Old Mar 16, 2006 | 10:22 PM
Showme's Avatar
Shifting between 64-6500 rpm
-Tim
Old Mar 16, 2006 | 10:47 PM
Chopstix's Avatar
I was trapping 120 w/4.10's in 4th gear on 26" tall tires
Go to the track and est. your 1/4 there
Old Mar 17, 2006 | 05:01 AM
Showme's Avatar
Thanks for the replies.
Your car is getting somewhere fast. What was your shift point?
-Tim
Old Mar 17, 2006 | 07:07 AM
97FormulaWS-6's Avatar
That's the issue with 4.10's and an upped redline. Thus the reason most people with any decent mods go with a 3.73 setup out back due to this exact reason.
Old Mar 17, 2006 | 08:47 AM
TQdrivenws6's Avatar
Hate to break it to you but you're not running that fast in the 1/4. 6500rpm + 4th gear + 4.10s on a 25.7" tire equals 122mph. Keep your gears and tires and take it to the track.
I went to 4.33's to go out the back door near redline in 4th, and if you shift at 6500rpm, your current tire/gear combo should be very close to optimal.
Old Mar 17, 2006 | 09:50 AM
OBE1 95Z28's Avatar
A 17X11 rim or a 285/40/17 isn't going to change you "gear ratio". They both end up having a diameter of approximately 26". You'd need to step up to a 27" or 28" diameter setup to stay out of 5th gear.
Here's a link to a gear/speed calculator:
http://www.f-body.org/gears/
Old Mar 17, 2006 | 12:25 PM
quicksilver97ta's Avatar
Originally Posted by Showme
Hello,
Thanks,
Tim
I bet your "estimated 1/4th" is off, take it to the track as mentioned.
Old Mar 17, 2006 | 05:48 PM
Showme's Avatar
Thanks for all the help and advice fellas.
I'll followup on the info as soon as I can.
-Tim
Jeff1904
Jun 5, 2016 05:00 PM
WobblySausage
Oct 7, 2015 10:09 AM
marlar98
Sep 19, 2015 07:53 AM
cmsmith
Sep 14, 2015 09:25 PM
CARiD
Sep 7, 2015 08:21 AM
