how do i set my timing?
Old Mar 16, 2006 | 11:26 AM
red_z28onthejuice's Avatar
Question how do i set my timing?
hey guys i have installed a zex nitrous system and it says to advance or retard my timing and i was wondering how i would go about doing that?
Old Mar 16, 2006 | 11:38 AM
Re: how do i set my timing?
i know that the ecu will reset any adjustment i make to thetiming but if i was to buy a power programer like those from summit or jegs catalogs would i be able to hack into the timing and set it that way?
Old Mar 16, 2006 | 02:20 PM
Bow94z's Avatar
IS the motor stock? Stock tuning? WET OR DRY SHOT? More info of your exact setup
How much of a shot are you gona throw at it?
Old Mar 17, 2006 | 12:39 PM
Joe B's Avatar
Do yourself a favor if you haven't already, and get yourself a MSD digital 6 ignition box (or equilivant) so that you have a much hotter spark, as well as a revlimiter that will cut spark "NOT" fuel, like the stock factory limiter... if you hit the factory revlimiter by accident just one time while spraying, It will be goodbye motor......With the digital 6 you'll also be able to dial in exactly how much timing retard you want to pull out when you arm the nitrous.....I would also send in the PCM to have the stock rev-limiter raised up to it's max (around 7200) so it's no longer in the picture........
Old Mar 17, 2006 | 12:57 PM
CustomSSI's Avatar
Very good advice there. Thats the proper way to do it. Or you could have it all tuned out of the computer but the timing is gone all the time. Whereas the box will only retard when nitrous is on...... We could get you a deal on one so give us a shout if your interested...
Josh
Old Mar 17, 2006 | 02:05 PM
thank you so much for your information guys. and ill check out your website
Old Mar 17, 2006 | 02:09 PM
the motor is stock,no tunning,and the system is dry,i have 100 shot injectors setup right now
Old Mar 17, 2006 | 02:29 PM
CustomSSI's Avatar
Didn't even think about asking is this an LS1/LT1 or what is it on?
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
