Low Oil Light
Old Mar 14, 2006 | 10:03 PM
19z28camaro02's Avatar
Exclamation Low Oil Light
Alright, I know, the Low Oil light on the 4th is notorious for illuminating. How do I get it to turn off and yet still be functional? Dealer(how much)?
Old Mar 15, 2006 | 09:51 AM
Re: Low Oil Light
The low oil light is turned on by the oil level sensor on the side of the oil pan. It does not have anything to do with the computer.
Make sure the sensor is OK and the wires are connected. The only way to turn of the light is to A) fix the problem, or B) pull the bulb out. Not sure what you mean by "still be functional".
Old Mar 15, 2006 | 01:34 PM
jsetzer's Avatar
Re: Low Oil Light
I have seen several with high miles have the sensor break. Its a long stick thing that goes in the side of the pan and the tip of it screws up.... Mine broke. Got a new one when I rebuilt the motor.
Check wires, that will do it too. If you want to turn it off all together...... (bad idea) cut the wires off the sensor. (I forget if they need to be connected or left undone. Quick trial/error will tell you that though.
Old Mar 16, 2006 | 06:53 AM
cehan's Avatar
Re: Low Oil Light
The low oil sensor is just a switch. If you determine the sensor is bad, and you don't want to change it out (or if you can't change it out because you have a Canton oil pan and long tubes like I do ) just short the 2 wires together and the light will go away.
Old Mar 16, 2006 | 12:49 PM
infinitebird's Avatar
Re: Low Oil Light
I have this on my car and the sensor is definitely the problem, as I have verified the actual oil level is fine.
transam_388
Mar 15, 2015 11:53 AM
Jan 23, 2015 01:13 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
