Who has NOT had problems w/ their Spec Clutch??
Old Mar 12, 2006 | 11:12 AM
Bayer-Z28's Avatar
As the title says. I'd like to seriously know who has NOT had problems w/ their Spec clutch/PP or different FW setup.... (Reserarch for others aswell as myself.)
What did you do that maybe different than other PPL? (refering to install) PN's? Hydraulics? What failed and/or what was fine. Is there a problem w/ common years/applications? What could be done to prevent future problems?
Old Mar 12, 2006 | 11:22 AM
Compstall's Avatar
Re: Who has NOT had problems w/ their Spec Clutch??
Almost 20,000 on mine. I'm using the stock flywheel and stock master cylinder.
Old Mar 12, 2006 | 11:38 AM
Camaro97USAF's Avatar
Same here installed a stage 3 on a stock flywheel that was milled down, stock hydraulics, still running strong almost 35k miles later.
Old Mar 12, 2006 | 01:04 PM
StudyTime's Avatar
Mine died after 8K miles. It was a stage III with their billet steel 'wheel.
Ben T.
Old Mar 12, 2006 | 02:28 PM
Compstall's Avatar
Ben T.
This is a NON-problem related thread. Thanks anyway.
Old Mar 12, 2006 | 02:30 PM
Loadre's Avatar
Had a buddy kill a stage two (just completely wore the lining off) then I stuck a stage III in it with stock resurfaced PP and stock hydraulics and he loves it.
Old Mar 12, 2006 | 06:09 PM
CamaroBoy96Z28's Avatar
My Stage II is perfectly good. I just pulled it out because of some phantom grinding noise in that area. I have just under 3k on it and it looks great.
Old Mar 12, 2006 | 06:27 PM
v7guy's Avatar
had mine for 10,000 miles and two years and no problem, stg 2, stock flywheel
Old Mar 13, 2006 | 07:49 AM
Bayer-Z28's Avatar
THe negitive responses are fine. but this isn't srictly a complaint thread.
Mabie there is a problem w/ their flywheels. You would figure a company that invests money to produce these would have them work correctly.
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
