Driver's side blinker does not blink anymore.
Old Mar 9, 2006 | 08:06 AM
Tokuzumi's Avatar
I had a crack in my driver's side tail light, and it filled up with water, and now my blinker won't work. It just stays on. The passenger side works fine. Would replacing the flasher work for this, or is there something else going on? I don't know whether the hazard lights work, as I have never used them. Let me know your thoughts. Thanks.
Old Mar 9, 2006 | 08:12 AM
kick Z tail out's Avatar
Re: Driver's side blinker does not blink anymore.
I was going to say flasher.
Old Mar 9, 2006 | 09:06 AM
Z28SORR's Avatar
The hazard and blinker flashers are separate. The blinker controls all turn signals, so if any of them work it's not the flasher. You've most likely got a rusted/corroded bulb socket.
Old Mar 9, 2006 | 10:23 AM
Koby's Avatar
If you taillight isn't working then it will make your turn signal stay solid like that too. Make sure you don't have a short in your taillight and try replacing your bulbs back there and see if that works.
Old Mar 9, 2006 | 10:27 AM
Tokuzumi's Avatar
I think Z28SORR has hit the nail on the head. I do have a rusted socket. How do I replace that, as that thing is soldered to the wiring. Or can the sockets be unplugged? Or should I try sanding the inside of the socket and see if that helps any?
Old Mar 9, 2006 | 01:06 PM
neil350's Avatar
Exactly, far as the tail light socket goes, you can get replacement sockets from the auto parts store, how you connect them is up to you. You can soder or use butt connectors
Old Mar 9, 2006 | 01:11 PM
km9v's Avatar
Sometimes the blinker bulb is dual filament & will stay lite when 1 filament is burt out. Replace bulb.
Old Mar 9, 2006 | 02:29 PM
meissen's Avatar
When your blinker bulb burns out, like km9v said, your signal will stay solid and won't blink. I'd say replace bulb first.
Old Mar 9, 2006 | 02:33 PM
Tokuzumi's Avatar
The bulbs have been replaced, but I do have rusty sockets from the tail light having about a gallon of water in it for an indeterminate amount of time. The brake lights come on, so that would mean the blinker would/should work too, right?
Old Mar 10, 2006 | 01:03 AM
L44's Avatar
L44
if the socket is corroded you can clean it out with a moist cotton swab and baking soda, i would recommend disconnecting the battery first before doing this. then you can wrap a light grit sand paper around the end of a pen and clean off the terminals inside the socket, then clean it out with the swab again. I would recommend using a dielectric grease on the bulb terminal/threads next time this way you will most likely avoid corrosion if this happens again. this may or may not work for you, but it has for me in the past, good luck.
Old Mar 10, 2006 | 10:37 AM
Z28SORR's Avatar
Good advice, but if it's got a lot of corrosion you wouldn't get it all and will be doing this again in a couple of months. Best bet is to replace the socket and use the dielectic greese on it.
Old Mar 10, 2006 | 10:40 AM
Tokuzumi's Avatar
Thanks everyone. I purchased two new sockets, and will be putting them on this weekend.
Keenan
Jan 19, 2023 12:24 PM
96SilverRam
May 5, 2015 09:56 PM
dale3in98
Feb 14, 2015 12:18 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
