No power to new head unit...?
Old Mar 8, 2006 | 08:47 PM
wyomble's Avatar
I just installed a pioneer DEH-P3700MP and it has no power. I got the cd player from someone who had it in a saturn for 1 month. The only thing i can think of is that there might be a different connector that goes into the back of the cd player itself. I don't know though. I spliced my camaro connector to what was there. Any suggestions? The ignition wire is attached. I left the other connecter in the stock radio unplugged. I believe that is the steering wheel controls.
Alan
***Edit; It was the "ON" button*** I hope I don't make that mistake again
Old Mar 9, 2006 | 01:37 AM
LS1 RULZ's Avatar
Re: No power to new head unit...?
The steering wheel controls are a single wire that is part of the factory HU's main wiring haness. The other flat connector is for the factory changer controls. I would say that you wired your new HU wrong. It's either that or because it's a Pioneer. I've been involved with car audio for over 30 years now and in that time I've learned that I wouldn't own a Pioneer if you gave it to me.
Old Mar 12, 2006 | 10:20 PM
danny525's Avatar
i agree, take the pioneer, and use it as a wheel block. But if its what you got, you wired it wrong. let someone do it for you, pay the 40 bucks, and a lot of head ache.
Old Mar 13, 2006 | 09:51 AM
VTsullyman's Avatar
Wow there always Pioneer haters in this group. I dont know if mie has just been a freak fo nature or what but ive had it for 3 years and transfered it into and out of 3 cars and into my current one. Never even skipped. Please explain the hate of pioneer HUs.
Old Mar 13, 2006 | 09:47 PM
Fuji_LT1's Avatar
i have a premier 940 and its AWESOME!!! clean and clear. best deck i've ever owned, and i've had excelon,alpine,clarion (pro)...etc. pioneer is just fine, depending on what you want to do....like many parts for our rides...
On your problem dont cut into factory harnesses go get the proper harness that takes the place of your deck to eliminate any room for error. if you dont have any power, look to your switched power, if the car isn't sending the signal to tell your deck to turn on then thats y, also you can double check your power and see if its always on, then run a second wire to your deck as the remote to get it to turn on, this will leave the radio on and will drain your battery so use this only to test don't leave it like this if it works. run it right. i agree with the post above though if you don't know what your doing pay to have it done right. 40 is about what a retailer would charge for labor, beware if you cut your harness to bad then there will be a few extra parts involved with the cost.
good luck
Old Mar 13, 2006 | 09:48 PM
Fuji_LT1's Avatar
oh and there is only one connector for pretty much all decks save things like dvd and nav systems. check your remote and stupid stuff like fuses
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
InfernalVortex
Jan 17, 2015 09:35 AM
thenewkid
Nov 27, 2014 09:41 AM
