How big with 2.055 valves?
Old Mar 7, 2006 | 10:22 AM
UltraZLS1's Avatar
I got a good deal on a set of 64cc patriot stage 2 ls6 style heads.
They have 2.055/1.57 valves and are unmilled.
Stock bottom end, stock gaskets.
Anyone have any prior experience/knowledge of approximately how big I can go without running into P to V clearance problems.
I am still considering upgrading my cam....how big can I go?
I want something in the range of 230-234 in the range of .580-.600 lift.
Something fm13ish
Nothing massive as I dont want to kill the cars street manners.
Would something with a split duration that is bigger on the exhaust side....like a g1 cam, would that help me out ?
thanks
Old Mar 7, 2006 | 10:51 AM
Kraest's Avatar
Retired
Re: How big with 2.055 valves?
I'm using the 2.055 valves in my heads with an F-15 236/239 with .600/.611 lift and the heads have been milled .020" and have minimal PtV clearance.
That's using the new Dart heads which have great PtV clearance. I don't know about the Patriot heads, though. I'm sure that you would be fine with the F-13 and no milling and stock head gaskets and would even probably be fine if the heads were taken down .020 or a thinner gasket was used.
Mike
Old Mar 7, 2006 | 12:19 PM
teke184's Avatar
you should be fine with any cam in the 230-234 range.
go check out the FM 13 or 14 cams from www.futralmotorsports.com
or the Torquer (new version) from TSP
Old Mar 7, 2006 | 03:56 PM
UltraZLS1's Avatar
I like the added power of the xer lobes but I am kind of scared of them.
The futral cams have slightly less of a ramp rate....but stories about the f13 eating up lifters is kind of worrying me....decisions decisions.
Anyone else?
Old Mar 9, 2006 | 10:29 AM
Kraest's Avatar
Retired
Anyone else?
The problem with the Cam Motion-designed cams has been addressed by Futral. There were a couple of bad batches from Cam Motion that floated around. There is also an oiling issue when using any high-revving cam and stock lifters... the bad batch only added to the problem and tore up people's stock lifters and the cam itself.
The new cams will be ground on a better core and polished. Nothing to worry about anymore.
Mike
Old Mar 9, 2006 | 10:52 AM
UltraZLS1's Avatar
Well...will an f13 clear 2.055 valves on an unmilled head?
Old Mar 9, 2006 | 01:27 PM
Kraest's Avatar
Retired
Easily. My F-15 is clearing with a .020" milled head.
NewsBot
May 15, 2015 08:10 AM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
Louey
Pacific
Apr 7, 2015 02:10 AM
MadMav
Feb 6, 2015 11:02 PM
