PCV question
Old Feb 28, 2006 | 03:45 PM
T56LS102's Avatar
PCV question
Prob. a dumb question but where is it located on a 02 Z28, and also what is the simplest way of changing it out.
Have any pics of its location??
Old Feb 28, 2006 | 05:30 PM
Brian's 01 SS's Avatar
Re: PCV question
The pvc valve is located towards the rear of the drivers side valve cover.
To change, remove the coil packs on the drivers side, push the air pump slightly up to gain access. The air pump is small and will be in the way. pull it out.
Old Feb 28, 2006 | 07:41 PM
blacknight's Avatar
Re: PCV question
The pcv isn't on the driverside. It's on the passenger side. Behind where the throttle cable is look for a hose going into the side of the intake. There is a wire cable wrapped around it thats bolts the head. To remove it just pull the hose off the intake and the pcv and pull it out of the rubber boot.
blacknight's Avatar
Re: PCV question
Old Feb 28, 2006 | 11:53 PM
AL SS590 M6's Avatar
Moderator
Re: PCV question
What he said.
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
grgguy
17
Feb 23, 2015 07:57 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
