how to get off stuck hose?
Old Feb 28, 2006 | 03:39 AM
danny525's Avatar
Question how to get off stuck hose?
top heater hose is stuck on real good, any ideas how to get it off?
Old Feb 28, 2006 | 07:00 AM
moparman's Avatar
Re: how to get off stuck hose?
You may have to cut it and replace with a new hose.
Old Feb 28, 2006 | 07:44 AM
Twist and pull.
Old Feb 28, 2006 | 11:41 AM
sabre81's Avatar
usually some channel locks around where the hose connects to the pipe works for me. Use some muscle wussy!
Old Feb 28, 2006 | 12:52 PM
danny525's Avatar
i can bench 340 pounds, i dont think muscle is an oblject lol
Old Feb 28, 2006 | 01:20 PM
ROADRAGE's Avatar
Squeeze a small screwdriver or pick between the hose and the radiator neck and run the screwdriver/pick around the inside of the hose. should come off easy after that.
Old Feb 28, 2006 | 01:27 PM
94Camaro_Z_28's Avatar
If you can get a screwdriver up in there, thats probably the easiest way. If all else fails, cut it with a utility knife parrallell to the hose from the end of it to about 2 inches back, peal it off and replace it.
Old Feb 28, 2006 | 03:17 PM
MasterEvilAce's Avatar
I did the screwdriver when I had to replace waterpump on my thirdgen.. Works very well. Pry it a bit to loosen it up
Old Feb 28, 2006 | 04:05 PM
2001NBMZ28's Avatar
Utility knife.
Old Feb 28, 2006 | 10:01 PM
1quickTA's Avatar
I usually put a small screw driver under the edge and spray a little water or WD40 or something in there to help break the seal. Then just wiggle the screw driver and twist the hose.
Old Feb 28, 2006 | 11:30 PM
danny525's Avatar
used a screwdriver, just had to take off a few things to get to it, thanks for all the advise.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
