Speedo and Tach messing up bad
Old Feb 27, 2006 | 10:21 AM
Craddock's Avatar
Ok, when it's really cold outside my speedo and tach and messing up. The Tach messes only when I first start the car and it's real cold. It jumps all over the place erratically (sp?) and it doesn't stop until it warms up. The engine runs fine I can hear it shift and all that. The speedo isn't as bad for going completely crazy. It just jumps up 20 or so miles per hour when I turn right. Then it slowly drifts back down when I go straight or turn left. This only happens when it's cold (about 40 degrees or below). Any ideas on what it could be?
Old Feb 27, 2006 | 11:22 AM
Dave89IROC's Avatar
Re: Speedo and Tach messing up bad
poltergist
sorry, temp related electrical stuff is usually hard to diagnose in person, let alone over the net
you need to put a scanner on it, and see what the PCM is seeing when it happens
could be PCM, wiring or cluster
Old Feb 27, 2006 | 11:33 AM
bmotwani's Avatar
sorry, this maybe besides the topic, since i'm just about to purchase a manual online, would you recommend Chiltons or Haynes repair manual??
Thanks...
mr28
Apr 20, 2016 05:44 PM
mr28
Nov 23, 2014 11:11 AM
guionM
Jul 21, 2002 04:38 PM
formula79
72
Jun 29, 2002 08:18 PM
