MSD blaster
Old Feb 27, 2006 | 08:17 AM
coogsLS1's Avatar
MSD blaster
what have you guys heard about those MSD blaster coil packs for the LS1s?
good upgrade even though it may be a bit expensive?
I heard they were going for around 85 a piece
Old Feb 27, 2006 | 08:57 AM
teke184's Avatar
Re: MSD blaster
stock coil packs are regularly supporting 500+ hp...
don't see much reason to upgrade...particularly for $700
Old Feb 27, 2006 | 10:18 AM
coogsLS1's Avatar
Re: MSD blaster
i was wondering, i heard you can get some good hp gains tho
Old Feb 27, 2006 | 11:16 AM
teke184's Avatar
Re: MSD blaster
heard from who??
maybe if you are running something like a nasty 408 or 427 stroker with a huge cam.
but one coil per cylinder provides more than enough spark for most applications.
upgraded coils on single-coil systems can yield good gains...like the LT1...but there can't be much to gain over the stock LSx setup
Old Feb 27, 2006 | 01:50 PM
iamsickofitall's Avatar
Re: MSD blaster
consider them a bling mod and a bling mod only - you'd need a damn impressive setup to make them a worthwhile performance mod - and FYI you can get them for well under $500 at some places
Old Feb 27, 2006 | 03:59 PM
rwb's Avatar
rwb
Re: MSD blaster
The ingnition system on LS1's is one of the few systems done right. Unless you have constant multiple missfires and can't trace it down, then you might try a couple of them, otherwise leave well enough alone.
Old Feb 27, 2006 | 11:32 PM
Bayer-Z28's Avatar
Re: MSD blaster
Same here....
They'd look kewl....that's it...
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
