another lca relocation bracket question
Old Feb 26, 2006 | 10:10 PM
cabe_z28's Avatar
when you install the bolt-in brackets, what are the little tabs for?
do you mount the shocks there, or to the stock location on the axle?
some relocation brackets have them, and some don't.
so i am wondering;
what are they for???
Old Feb 27, 2006 | 06:38 AM
teke184's Avatar
Re: another lca relocation bracket question
thoes are what prevent the brackets from rotating.
they go on the mounting bracket for the lower shock mount.
i edited this pic from my brackets, you can see where the tab is. it prevents the bracket from pivoting back or forward under load (big arrow). other wise the only mounting hole would be the upper bolt. the tab kindda triangulates it.
Old Feb 27, 2006 | 10:02 PM
cabe_z28's Avatar
thanks for that pic, helped out alot.
Old Mar 1, 2006 | 06:28 PM
smallblock458's Avatar
Do these relocation bracket's make a differance or are you better off with an adjustable torque arm? Or should both be used together to get the best instant center?
Old Mar 1, 2006 | 08:53 PM
Bud M's Avatar
The only effect of the torque arm's adjustablility is on pinion angle.
Old Mar 2, 2006 | 07:33 AM
teke184's Avatar
i think the brackets make a bigger improvement on the rear suspension.
but i am by no means an expert.
all i know is that my car squats and grips with zero wheel hop and good traction, and i'm on stock TA.
Old Mar 2, 2006 | 12:47 PM
Honda Hunter's Avatar
I read in another thread theyre not a must.
Old Mar 2, 2006 | 09:08 PM
cabe_z28's Avatar
i have also heard they are not a "must."
but they are recomended, otherwise you will go through u-joints like a ****.
Old Mar 3, 2006 | 09:25 AM
What is not a "must"? Relo brackets or an adjustable TA?
The LCA relo brackets are, based on my experience, one of the best things you can do for straight line traction. They increase the lift on the body, and increase the down force on the tires.
Old Mar 3, 2006 | 09:44 AM
respectirocz's Avatar
the bolt in relocation bracket is located by that tab that is sandwiched by the shock
what about the weld in relocation brackets, how are they located
Old Mar 31, 2006 | 06:56 AM
teke184's Avatar
the weld in ones are located according to the bolt holes and the LCA i think...then obviously held in place with welds. no need to "triangulate" them.
94B&RZ-28
Dec 22, 2008 10:00 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Waste
Jul 31, 2002 11:59 PM
twistedwedge
Jul 27, 2002 01:54 PM
