LS1 and Jacob's nitrous mastermind
Old Feb 26, 2006 | 12:22 PM
RedTtop6spd's Avatar
I recently got a Jacob's nitrous mastermind and was going to put it on my 87 camaro, but have decided to not bother putting any money into that car and not spray it anymore. Instead I'm just going to put money into my 99SS and upgrade the stuff that I have in there. Is there any way to connect the mastermind to the LS1? The general instructions say that it requires the use of an aftermarket ignition system. Is this still required to use it on an LS1 and if so, what's available for me?
Old Feb 26, 2006 | 02:49 PM
HarrisSpeedWorks's Avatar
Re: LS1 and Jacob's nitrous mastermind
You should be able to use the progressive feature no problem. I don't think you will get the Retard feature or the Rev Limit to work. You might get the mastermind to trigger a LS1 Timing Tuner and have that pull timing, or change out the COP system to a distributor based and then use the mastermind to control the timing on the spray.
Matt
Old Feb 26, 2006 | 02:56 PM
That's what I thought. I was hoping to be able to get the timing retard to work without too much extra. Timing tuner is $250 correct?
Old Feb 26, 2006 | 05:57 PM
Yes. Do you know what kind of out put the mastermid provides for controlling timing?
Matt
Old Feb 27, 2006 | 09:13 AM
Sends trigger signals.
Old Feb 27, 2006 | 01:04 PM
If it sends out either a ground or 12v you could use it to trigger the LS1 timing tuner. It's a little tricky as you would have to use the output to trigger a relay or something (like a LED light or resistor) between the white and gray wires on the LS1 timing tuner.
Matt
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
95blkss
Sep 22, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
