Need clutch master cylinder help.
Old Feb 25, 2006 | 01:53 AM
96ZCamaro's Avatar
Ok well I just got my new clutch master/slave cylinder today. How do you get the end of the master cylinder off that attached to the pedal? Cant see in there at all. Any help appreciated.
Old Feb 25, 2006 | 03:58 PM
rngilliland's Avatar
Re: Need clutch master cylinder help.
There is a small clip that has to be removed then the rod just slides off the stud on the pedal.
Old Feb 26, 2006 | 01:25 AM
96ZCamaro's Avatar
If you are looking towards the dash, what side is the clip on. And how do you go about getting it off? All I know is when I reach my hand in there I can spin somthing around on the end of that....
Old Feb 26, 2006 | 07:32 AM
cehan's Avatar
It is a PITA. You remove the dashboard knee bolster, get the driver seat as far back as you can, get a light in there so you can see, get on your back and wiggle up under the dash as far as you can. Then, use a small screw driver to pry up on the retainer part of the clip and at the same time push back on it til it moves up to the part with the larger ID and it will pop off the pin. Then look around on the floorboard to find out where it landed.
Getting it back on is almost as bad.
Chris
Old Feb 26, 2006 | 02:48 PM
96ZCamaro's Avatar
lol. Well ok thanks for the help. I think I can figure it out. Sounds like I got quite the job ahead of me with this exhaust and this stupid master cylinder thing.
Old Feb 26, 2006 | 06:01 PM
cehan's Avatar
Yeah, then the fun really begins when you finally get get the master cylinder U-bolt off and wriggle the cylinder out from behind the power brake booster and then have to put the new one back in.
Chris
Old Feb 26, 2006 | 11:10 PM
96ZCamaro's Avatar
Sounds like a two person job to me. But I am hopeing it will not be that hard with the exhaust off and whatnot.
Old Feb 27, 2006 | 07:03 AM
cehan's Avatar
I did the R & R by myself, but it would definitely be easier with a second person.
Chris
Old Feb 28, 2006 | 11:03 PM
96ZCamaro's Avatar
Alright, well thanks for the help, I ended up getting it done today. Quite the job I have to say, but was very rewarding when done. Had a sense of acomplishment, lol. It was way worse getting it back in then it was getting out....I just had to get tempermental with the old one to get it back out
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
timmy39120
May 2, 2015 05:12 PM
Ringmaster72
Mar 19, 2015 03:32 PM
