door skin coming loose
Old Feb 12, 2006 | 09:50 AM
dcatch01's Avatar
what kind of adhesive would anyone recommend for a oem equivelant to reapply the door skin by the handle. Not sure if someone tried to break into my car, or was just a poor job of assembly. thanks for any help.
Old Feb 12, 2006 | 12:00 PM
n2ceptor's Avatar
Re: door skin coming loose
Found at most car paint stores, and part stores....
Old Feb 12, 2006 | 02:40 PM
Craddock's Avatar
I've looked this up and I'm just taking mine to a body shop and making sure it's done right because everyone says that most if not all of the stuff you buy at the store doesn't work.
Old Feb 12, 2006 | 02:55 PM
Dave89IROC's Avatar
structural adhesive is what is needed
Old Feb 13, 2006 | 12:30 PM
dcatch01's Avatar
i sure wished it was the drivers door. i would remove the whole skin and repair my window motor while i was at it. just my luck passengr side motor works jut fine
Old Feb 13, 2006 | 12:46 PM
TraceZ's Avatar
Originally Posted by dcatch01
I sure wished it was the drivers door. I would remove the whole skin and repair my window motor while I was at it. Just my luck passenger side motor works just fine.
Why on earth would you remove the outer door skin to R&R a window motor? They are easy to replace from the inside panel! Follow Shoebox's guide and you will be done in less than 1 hour.
Old Feb 13, 2006 | 10:39 PM
user name's Avatar
That sounds more like it. Any idea where one might procure this (an actual source and/or brand, for us non-engineer types. ). Thank you for any insight you might have. :nice:
Old Feb 14, 2006 | 12:21 AM
Dave89IROC's Avatar
heres some
http://www.sjdiscounttools.com/sem39337.html
http://www.lord.com/Default.aspx?tabid=1193
check with a local painters supply and see if they have some type, there are many different brands, the 2 part is best, but the 1 part is fine, especially since the skin hasn't come all the way off(1 part/single stage has a slightly longer cure time)
Old Feb 14, 2006 | 01:40 AM
user name's Avatar
heres some
Thank you very much for the links. I might need to hit the local paint supply shop for interior dye so I will ask there first (now I kinda know what I am lookin for, and that it ain't real cheap).
FWIW, in case it helps folks, I had tried a two part epoxy for plastics originally. Application was an issue (getting the epoxy into the crevice) but it was clean in there, etc and applied decently. It held for a couple weeks maybe, before letting go again (upper right hand corner of the door, adjacent the exterior door handle).
Thank you again for the info and links.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
MJ_Z28
Aug 7, 2002 07:15 PM
