Wires...
Old Feb 9, 2006 | 08:07 PM
chris96camaro's Avatar
Wires...
Where did you run your power wires? I know mine go under my car..but i didnt install them, and i would like to know how much of a pain it is to run them...i have a friend with a 2002 camaro who needs to run a wiring kit for his subs...thanks
and can you run the remote on wire yourself..since it has to be hooked to the head unit?
Old Feb 9, 2006 | 09:19 PM
PentaVolvo's Avatar
Re: Wires...
extremely easy to do under hood unbolt pcm and lift it up there is a huge grommet to go through then unbolt the peace inside the door the sill or whatever and route the wire. remote wire goes from headunit to amp
Old Feb 10, 2006 | 09:13 PM
Re: Wires...
is there any holes that need to be drilled in order to do this? or can i use all pre-existing holes?
Old Feb 10, 2006 | 11:06 PM
PentaVolvo's Avatar
Re: Wires...
no drilling
Old Feb 11, 2006 | 01:19 AM
sir dyno's Avatar
Re: Wires...
Simple to run the wire. Check my website and go to page two, I have pictures so you know what to look for.
eanhl2004
Nov 18, 2013 11:05 AM
football4life
Jul 24, 2012 10:00 PM
SmokinZ28lt1
Jul 12, 2011 07:09 PM
Highlander
Feb 9, 2003 10:40 AM
